Split tunnel not working at one location
I have a VPN connection that a few remote sites use to connect in an in-house system. I have a PIX running 6.3(1). The remote sites are using vpn client 3.6.2(B). Split tunneling is enabled to allow the remote sites to browse the internet and print to local printers. A new site was added just recently and I have run into a problem. It seems that the split tunneling is not working for this site. They connect via the VPN okay and can access the in-house system but cannot print to their local printer. They also cannot connect to the Internet when connect to the VPN. With the split tunnel in place the other sites have no problem doing any of the above.
The trouble site is behind a Cisco 1721 on their end. Any idea on what might be causing this?
Thanks for any insight!
1 REPLY
Re: Split tunnel not working at one location
The ACLs for split and No NAT should be different, sometimes we see this problem when using same number for both of them.
Sincerely
Atul.
248
