split tunnel not working, please help
all my attempts to configure split tunneling for a vpn user (pix 515) do not work.
can some one please tell me why?
I have configured the vpn user with the vpn wizard at the pix pdm , I have marked the checkbox for split tunnel.
this is the config: (inside ip=192.168.1.0 )
vpngroup bezeqint split-tunnel bezeqint_splitTunnelAcl
access-list bezeqint_splitTunnelAcl permit ip 192.168.1.0 255.255.255.0 any
* the result is that the vpn client get access to internet but not to the internal network. when i disable the split tunnel , the user get access to the internal network without internet.
1 REPLY
Re: split tunnel not working, please help
you need to reconfigure the access-list
what is the address-pool that the clients get when dialing in?
if you assign your vpn clients addresses from another subnet/ a pool:
-i.e.
ip local pool vpnclients 192.168.2.1-192.168.2.254
and then define the acl as
access-list bezeqint_splitTunnelAcl permit ip 192.168.2.0 255.255.255.0 192.168.1.0 255.255.255.0
vpngroup superteam split-tunnel bezeqint_splitTunnelAcl
you should be ok.
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_configuration_guide_chapter09186a00800eb0b5.html#997762
81
