Split tunneling with LAN to LAN
Is it possible to split tunnel (like cisco VPN client to concentrator) using a LAN to LAN connection? The 3015 creates a tunnel to the 2621. What I want is to have the server2 talk to server1. Is that possible?
___ ______
3015 ---->Internet --------> | |--->_2621_|----->|server1|
|FW |
| _ __|---->|server2|
1 REPLY
Re: Split tunneling with LAN to LAN
Generally what happens through Split tunneling is that the Traffic that needs to be encrypted is sent through the VPN tunnel and the rest of it goes out normally through the ISP connection to the internet. What I am not sure about is if the FW is actually a PIX, because usually you cannot bounce off a firewall to go back out the same interface? is that what you are trying to do? If you are trying to go out another Interface of the Firewall then this will work without any problems provided all the Routing is setup properly.
Hope this helps,
Aamir
81
