Split Tunneling without using Cisco VPN client?
Hi all. I have an 1811 that works great for inbound VPN connections as long as the client pc uses the Cisco VPN client. Can I just use the built in VPN/Ipsec that Windows provides and still get split tunneling?
I'm looking for a work around to allow split tunneling but not use the Cisco software.
Any thoughts would be appreciated.
1 REPLY
Anonymous
N/A
Re: Split Tunneling without using Cisco VPN client?
I think it is possible. Make sure that NAT is configured properly and particularly NAT 0 ACL is correct. I think you may need to enable one-arm routing. Following link may help you
http://www.cisco.com/en/US/docs/security/asa/asa71/configuration/guide/vpnsysop.html
273
