split tuuneling
Do all cisco powered networked ISPs supports split tunneling ?
Do I have to make any configurations to use split tunneling?
1 REPLY
Re: split tuuneling
Split tunneling allows client users to access other Internet sites while securely tunneled to the VPN termination point. To answer your question, it should be no problem across any network whether it’s Cisco powered or not. What product do you need to configure split tunneling for? You might want to check out the configs at cisco.com if you’re using a Cisco product. That is typically where I get my configs from.
Hope this helps
180
