Community Member
Spoke to Spoke VPN via Hub
All,
Please find attached the diagram and HUB /SPOKE configs I am using to get spoke to spoke communication via the VPN hub.
The VPN is functioning correctly between the hub and spokes just not between the 2 spokes! please help!
1 REPLY
Re: Spoke to Spoke VPN via Hub
This is a common problem. The router in the hub will discard the traffic since a packet cannot exit the same interface it entered.
Try the following commands on the hub outside interface:
no ip route-cache
no ip route-cache cef
no ip route-cache flow
If this doesn't work, you might need to implemetna a GRE/IPSEC implementation, with the hub having one GRE interface for each spoke.
Please rate if this helped.
Daniel
136
