spwr0 not sniffing
I have a remote sensor (4230) that just slowly stopped sniffing traffic. Right now all it sees are ARP (netbios) requests. This sensor is plugged into a brand new hub, with new cabling.
According to the log the sensors sniffing interface will come up for 1 minute then go down and stay down for 40 minutes. FYI this sensor has been replaced once (same problem). Are we looking at something environmental? Or a known bug? This sensor is configures the same as many others that we manage, yet it is the only one exhibiting this problem.
Any help......Thanks
Re: spwr0 not sniffing
BTW .... Current Sig version is 3.0(5)S23
a few questions: If you unplug the cable then plug it back in, does the traffic start up again? Have you tried snooping the traffic to see if there is anything unusual right before it stops? Try doing a snoop with netrangr stopped. Does the traffic still quit after 1 minute. try connecting the sniffing interface to the same place as the command/control. Do the snoop. does traffic die there also??
With both cables plugged into a hub, that we know has 100k of traffic passing through, sniffing the spwr0 interface only shows us management traffic.
When the cables are connected correctly (one to managed router, sniffing to hub) we only see broadcast traffic (ARP whois).
This sensor was working just fine until over the course of 1 to 2 weeks it would sniff less and less traffic and then the sniffing just stopped.
Any help...we dont want to have to replace equipment
What model of hub are you using? it is sure acting like a switch....
We are using a 1538M hub.
104
