Community Member
SSC-400 with vpn spar doesn't reconize on 6509 with sup 720
When I insert ssc-400 included vpn spa in the 6509 with sup 720, I got the following log in terminal.
*Jun 17 01:56:11.191: %SPA_OIR-3-UNRECOGNIZED: The SPA of type 0x3D7 in subslot 3/0 is not recognized
*Jun 17 01:56:11.191: %SPA_OIR-3-UNRECOGNIZED: The SPA of type 0x3D7 in subslot 3/1 is not recognized
*Jun 17 01:56:11.203: %SPA_OIR-3-UNRECOGNIZED: The SPA of type 0x3D7 in subslot 4/0 is not recognized
*Jun 17 01:56:11.203: %SPA_OIR-3-UNRECOGNIZED: The SPA of type 0x3D7 in subslot 4/1 is not recognized
*Jun 17 01:56:44.171: %OIR-6-REMCARD: Card removed from slot 3, interfaces disabled
*Jun 17 01:56:44.171: %OIR-6-REMCARD: Card removed from slot 4, interfaces disabled
*Jun 17 01:57:05.359: %SPA-3-SW_ERROR: subslot 3/0 spa type 0x3D7: SNMP attributes not defined
-Traceback= 423B9D94 423B9F3C 423BA118 423BC770 423BCC50 423BCD90 423BD1C4 4135C734 4135C720
-Traceback= 423B9D94 423B9E34 423BA12C 423BC770 423BCC50 423BCD90 423BD1C4 4135C734 4135C720
*Jun 17 01:57:05.359: %SPA-3-SW_ERROR: subslot 3/1 spa type 0x3D7: SNMP attributes not defined
Mod Sub-Module Model Serial Hw Status
3/0 SPA-IPSEC-2G - 1.0 OutSrvc
3/1 SPA-IPSEC-2G - 1.0 OutSrvc
4/0 SPA-IPSEC-2G - 1.0 OutSrvc
4/1 SPA-IPSEC-2G - 1.0 OutSrvc
6 Policy Feature Card 3 WS-F6K-PFC3B - 2.5 Ok
6 MSFC3 Daughterboard WS-SUP720 - 3.3 Ok
Mod Online Diag Status
1 Pass
2 Pass
3 Pass
3/0 Not Applicable
3/1 Not Applicable
4 Pass
4/0 Not Applicable
4/1 Not Applicable
6 Pass
our soft version is like below:
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICES_WAN-M), Version 12.2(33)SXI1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Sat 28-Mar-09 10:30 by prod_rel_team
Image text-base: 0x40101328, data-base: 0x43661BB0
Please Let me check above symptops.
When I read the document, It has not problem to use vpn spa on sup 720 with SXI
1 REPLY
Re: SSC-400 with vpn spar doesn't reconize on 6509 with sup 720
Hi Sung,
Have you load the appropiate FPD image into the flash? Please find the following document for more info:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/release/notes/ol_14271.html#wp2430389
HTH,
jerry
657
