SSH from outside
Gentleman
I had a PIX firewall at a former customer running version 6.2.2. I used to sometimes set up SSH to the outside interface so that TAC folks could get access to the box.
I just purchased a 515 box running version 6.3.1. i dont see any options for doing ssh outside in this version of code? Is this correct??
Silver
Re: SSH from outside
ssh 0.0.0.0 0.0.0.0 outside
should allow everyone, everywhere to ssh to the pix, provided you have set up the hostname and the private keys
Thanks. Is there a link that explains the key setup. I looked for it on the web, but cannot find it...
Silver
ca generate rsa key 512
ca save all
should do it. you need to have the hostname and domain name for the pix defined first. then open up access to ssh via the aforementioned command, and try testing it
Thanks!
244
