ssh on pix using puty client
cfajardo1_2
i cant access my pix using ssh. i have configured the following. There is no access-list on the inside interface
INSIDE IP - 192.168.1.1/24
domain-name xxx.com
hostname Company
ca generate rsa key 2048
ca save all
ssh 192.168.1.0 255.255.255.0 inside
telnet and ping are ok.
thanks a lot.
6 Replies 6
kaachary
Try this :
ca zeroize rsa
ca gen rsa key 1024
ca save all
If you are using putty as SSH client, make sure, the SSH version 1 and 2 both are selected.
*Please rate if helped.
-Kanishka
ive tried 1024 before using 2048
scottmac
Level 10
Level 10
Which version of PIX OS are you using?
Some of the older versions do not support SSH, others (up to 6.35 I think) only support SSH version 1.
Good Luck
Scott
its a pix 525 with 6.3(4)
Are you able to telnet to port 22 from Command line ?
Does it open up a blank window ?
If yes, then ther's someting wrong with the SSH client you are using. Make sure putty is setup correctly. Also, did you verify that SSH 1 and 2 both are selected on it.
-Kanishka
peteruwa
You have mised out
"aaa authentication ssh console LOCAL" in your configuration. Add it and try connecting again.
pet
