SSH on red. Sup720
is there a way to synchronize the ssh key between the active and standby supervisor engine.
After a failover it is not possible to connect via ssh.
Andre
Re: SSH on red. Sup720
If I am not mistaken, the ssh key which is generated using the "crypto key generate rsa" command cannot be saved into router's common config file (startup-config) and be replicated into the standby SupEngine. You have to generate individual key in both modules.
What you can do is to bring-up the standby SupEngine, and configure the necessary/required ssh parameters like the hostname, & domain before generating the ssh key. I am sure the startup-config will be similar, except for the ssh.
If both hostname and domain name is simialr, then you only need to generate the ssh key.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124tcr/tsec_r/sec_c3ht.htm#wp1262148
Rgds,
AK
In this case we are running into a bug in 12.2.33 SRA. Normally the RSA keys should be sync'd to the standby sup.
andre
117
