SSL Certificate will expire in 27 days
We have a VPN 3005 Concentrator. We got an email notification "SSL certificate will expire in 27 daysIssuer. CN=XXX.XXX.XXX.XXX,O=Cisco Systems, Inc.,L=Franklin,ST=Massachusetts,C=US,OU=VPN 3...Subject: CN=XXX.XXX.XXX.XXX,O=Cisco Systems,Inc.,L=Franklin,ST=Massachusetts,C=US,OU=VPN 3... Expiration Date: 05/31/2008"
Do you have any suggestions on how to fix this problem?
Thanks.
1 ACCEPTED SOLUTION
Re: SSL Certificate will expire in 27 days
This applies to https management access to your vpn concentrator, you can have the concentrator self create a new certificate and install it in your pc that access the vpn for management, but you can uncheck client authentication which is default vpn concentrator thus not requiering certificate checks for network administrators accessing the device via ssl with certificate for client verification. The link bellow explains it and your question is there.
Your concentrator probably have checked client authentication. Again, you can uncheck that and not go through certificate management or recreate a new certificate and go through the process of managing and regenerating new certificates when they expire.
on concentrator you need to go to :
configuration/system/management protocols/ssl
See Q&A on your question
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_qanda_item09186a0080094cf4.shtml
Rgds
Jorge
1 REPLY
Rgds
Jorge
139
