08-02-2002 01:38 PM - edited 03-08-2019 11:48 PM
im sure im doing something silly here, but there seem to be few options:
my management interface works fine as long as i dont attempt an ssl connect. i have clicked on the little icon and followed the instructions to install the cert (and have verified that it IS installed; on 3 machines yet) but whenever i attempt the ssl connect, i get the lovely server not found message (i.e 5.0, 5.5 and 6.0)
i have verified that https is enabled and have not monkeyed with any of the settings there.
anyone else having this problem?
08-02-2002 04:13 PM
I would suggest trying to Delete the SSL Certificate server, under: Administration | Certificate Management , then make sure the time is correct and then Regenerate it again under the same page. This helps most of the times and works like a charm.
Hope this helps,
Aamir
08-03-2002 03:35 PM
worked like a charm!!!
thanks much
