ssl VPN client for Vista doesn't work
tlyowell1
I'm trying to find a way for my client swho are upgrading the PC to Vista to connect using web VPN to a ASA 5510.
any help would be great
5 Replies 5
acomiskey
Level 10
Level 10
SSL VPN client or clientless web vpn?
SSL Web client
I don't have experience with the ssl client and vista, but I do use the new Anyconnect SSL client with vista. All you need to do is upgrade the ASA to version 8. Hope that helps.
So I need to upgrade my ASA device to make this work?
If you want to use Anyconnect, yes.
