SSL VPN recieving errors when connecting to internal web servers
I get the following error when I try to connect to an IIS server on my internal network.
"You do not have permission to view this directory or page using the credentials that you supplied because your Web browser is sending a WWW-Authenticate header field that the Web server is not configured to accept. "
This server loads pages fine when accessed from the lan using the same system/browser.
ANy suggestions would be helpful.2
1 REPLY
Bronze
Re: SSL VPN recieving errors when connecting to internal web ser
To me, this looks like the authentication issue on the concentrator. Verify if you have permission to access the IIS server over the SSL VPN connection. Check this under the "User Management/Group Management" section of the configuration.
118
