SSLVPN and IPSec VPN on ASA 5520 with 7.1(2)
Hi Mynul,
I have setup two ASA 5520 on Active-Passive setup.
I have also configured the SSL VPN to work byproviding the users with SSL VPN Client for full network access.
I have also configured the IPSec VPN, however I have issue in connecting through the IPSec VPN. When I try to connect the IPSec VPN client always says that it can't connect to the Gateway. On the Gateway can see that it is saying that it doesn't have the correct proposal.
Following is the IPSec configuration I have,
ip local pool RAVPN-Pool 192.168.100.1-192.168.100.254 mask 255.255.255.0
group-policy RAVPN internal
group-policy RAVPN attributes
dns-server value 192.168.200.11 192.168.200.12
vpn-tunnel-protocol IPSec
default-domain value xxx.xxx.xxx.xx
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto dynamic-map DMZ0_dyn_map 20 set transform-set ESP-AES-256-SHA
crypto map DMZ0_map 65535 ipsec-isakmp dynamic DMZ0_dyn_map
crypto map DMZ0_map interface DMZ0
isakmp enable DMZ0
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption aes-256
isakmp policy 10 hash sha
isakmp policy 10 group 5
isakmp policy 10 lifetime 86400
tunnel-group RAVPN type ipsec-ra
tunnel-group RAVPN general-attributes
address-pool RAVPN-Pool
default-group-policy RAVPN
tunnel-group RAVPN ipsec-attributes
pre-shared-key *
I think there should be no problem to have IPSec and SSL VPN/WebVPN to work on the same ASA 5520 with ASA version 7.1(2).
Please kindly advice.
thanks,
Muljawan
1 REPLY
Re: SSLVPN and IPSec VPN on ASA 5520 with 7.1(2)
YOu should not have a problem running these two together. I have implemented both IPSEC and SSL VPN on the same VPN 3000 box. Just make sure you have enabled access for both IPSEC & Webvpn on the outside interface. By default, 2 webvpn sessions can be established on a ASA 5520. Over that, u might need to procure licenses.
Just to isolate the issue, you can disable webvpn and try to connect via IPSEC VPN and see if the parameters configured are correct.
Hope this helps. all the best...
rate replies if found useful
Raj
209
