05-14-2007 06:09 AM - edited 03-09-2019 05:59 PM
Hello all,
I have an ASA 5520 with an IPS module.
I lossed the password that I set before, and I wanna to recover. on the Cisco Website I found the command :
hw-module module 1 password-recover
but i don't found that command
Any suggestion??
05-15-2007 06:14 AM
hw-module module 1 password-reset will work if you are running 7.2 code and running IPS 6.0E1. Other wise you have to reimage the whole box.
Information about reimaging can be found in the following document:
-Hoogen
Do rate if this post helpls :)
05-15-2007 11:41 PM
Do a sh module 1 and paste it on here.
u need to find out what IOS u r running on your ASA and which IPS version is sunning on your AIP SSM module.
if IOS is 7.2(2) IPS versin is 6.0 then hw-module modile 1 password-reset command would work to change username / password back to cicso / cisco
if IPS is 5.0 then ul have to reimage the IPS module.
procedure can be fount at the Command line reference guide for IPS 5.0 ( under reimaging AIP SSM 10 section )
i just had the same problem myself :-)
reate if this post helps.
