Starting a tunnel before logging on W2K using SmartCard Certificates
Hi all,
I am trying to start a tunnel using a certificate stored on a GEMSAFE SmartCard before logging in, in oprder to propperly log onto the network using my certificate, but The Cisco VPN Client v3.6 says:
"The currently selected profile uses the Microsoft CryptoApi certificate store. This profile can not be used until you have logged in to your workstation".
But how can I stablish the tunnel with the certificate if I cannot read it?
Any ideas?
Thanks in advance.
1 REPLY
Re: Starting a tunnel before logging on W2K using SmartCard Cert
Listed below are two documents that might help you:
1) Configuring IPSec Between PIX and Cisco VPN Client Using Smartcard Certificates
http://www.cisco.com/warp/customer/471/configipsecsmart.html
2) Configuring the VPN Client 3.0.x to Get a Digital Certificate
http://www.cisco.com/warp/public/471/installmscert.html
I'm no MS expert but it is possible to log onto your workstation even if you are not logged on to the network. I pulled out my ethernet cabel and tried logging in and guess what... I got in. Perhaps you could try doing the same. I think that the problem might simply be that you are not allowed access to the certificate since you are not logged in.
98
