stateful failover question...
I have two pix 515 firewalls. I'm ready to configure failover.
I believe my best option would be stateful failover.
I have a 100 mbps ethernet interface available on both firewalls to allow for the passing state data.
Do I still need to make use of that failover serial cable???
Thanks.
Re: stateful failover question...
Yes you will need to connect serial cable also, as it is the one communicating with primary and standby units.The dedicated interface will allow to communicate the states .
Refer the following link
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_61/config/failover.htm
Thank-you. This is my first attempt at this...
84
