02-24-2004 05:18 PM - edited 03-09-2019 06:32 AM
Is it possible to use a Virtual Interface on the PIX (when 802.1q trunking enabled) for stateful Failover Information?
A serial cable will still be used for regular failover.
Naman
Solved! Go to Solution.
02-25-2004 06:36 AM
Naman,
Nope, sorry. The stateful failover link still needs to be a dedicated physical interface due to the sheer amount of traffic that is sent across this connection in most cases. Hope this helps.
Scott
02-25-2004 06:36 AM
Naman,
Scott
03-02-2004 08:24 AM
hi,,
No u can`t use virtual interface for stateful failover.u have to use dedicate cable.
For regular F.O u need use serial or ethenet cable
For serail === below 6feet
lan cable ===== above 6feet
bye
sat.
