You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Stateful FailOver
Is it possible to use a Virtual Interface on the PIX (when 802.1q trunking enabled) for stateful Failover Information?
A serial cable will still be used for regular failover.
Naman
  • Other Security Subjects
1 ACCEPTED SOLUTION
Re: Stateful FailOver
Naman,
Nope, sorry. The stateful failover link still needs to be a dedicated physical interface due to the sheer amount of traffic that is sent across this connection in most cases. Hope this helps.
Scott
Naman,
Scott
hi,,
No u can`t use virtual interface for stateful failover.u have to use dedicate cable.
For regular F.O u need use serial or ethenet cable
For serail === below 6feet
lan cable ===== above 6feet
bye
sat.
97
