Community Member
Static Command problem
Hi!
When I enable a static command to give access to an inside host from outside my connection to the outside drops, My access-list is as follows
access-list 101 permit tcp any any
access-list 101 permit icmp any any
access-list 101 permit ip 10.101.3.0 255.255.255.0 66.153.9x.0 255.255.255.240
Static (inside,outside) 66.153.9x .x 10.101.1.54 netmask 255.255.255.255 0 0
access-group 101 in interface outside
Where could be the problem.. Can somebody help
Anair
1 REPLY
Gold
Re: Static Command problem
Hi Anair,
From your list - are you just allowing one (1) outside host access to your inside network ? if so then the following document might be helpful to you:
http://www.cisco.com/warp/public/707/28.html#trust
Hope this helps... let me know how you get on....
Jay
86
