static nat not working.
I have run into problems configuring static nat on a ASA5510-K8 running software version 7.0(6).
Hope I can solve it with a little help from the experts in here.
I have a public subnet available.
First IP is in use by the router
Second IP is used for the ASA
I want to use the 5th (3rd and 4th in use by other hosts) to static nat to an inside hosts (https)
But though configured, it does not work.
This is part of my configuration.
ASA Version 7.0(6)
names
name 10.1.1.17 W2K-CXW-HRN
name 10.1.1.12 Esafe
dns-guard
interface Ethernet0/0
nameif outside
security-level 0
ip address xx.xx.62.34 255.255.255.248
interface Ethernet0/1
nameif inside
security-level 100
ip address 10.1.254.2 255.255.0.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
access-list outside_access_in extended permit icmp any any echo-reply
access-list outside_access_in extended permit icmp any any unreachable
access-list outside_access_in extended permit tcp any interface outside eq smtp
access-list outside_access_in extended permit tcp any host xx.xx.62.37 eq https
access-list outside_access_in extended deny ip any any log
access-list inside_access_in extended permit icmp any any echo log
access-list inside_access_in extended permit icmp any any echo-reply log
access-list inside_access_in extended permit udp 10.1.0.0 255.255.0.0 any eq domain
access-list inside_access_in extended permit tcp 10.1.0.0 255.255.0.0 any eq ftp
access-list inside_access_in extended permit tcp host Esafe any eq smtp
access-list inside_access_in extended permit tcp 10.1.0.0 255.255.0.0 any eq pptp
access-list inside_access_in extended permit tcp 10.1.0.0 255.255.0.0 any eq 3389
access-list inside_access_in extended permit tcp 10.1.0.0 255.255.0.0 any eq www
access-list inside_access_in extended permit tcp 10.1.0.0 255.255.0.0 any eq https
asdm image disk0:/asdm506.bin
nat-control
global (outside) 10 interface
nat (inside) 10 10.1.0.0 255.255.0.0
static (inside,outside) tcp 217.166.62.37 https W2K-CXW-HRN https netmask 255.255.255.255
static (inside,outside) tcp interface smtp Esafe smtp netmask 255.255.255.255
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 xx.xx.62.33 1
Did I make an obvious mistake?
Re: static nat not working.
Looks good have you done a " clear xlate " after changing or adding the static NAT ?
Take care this will reset all sessions.
sincerely
Patrick
Yes, I tried "clear xlate",problem remained.
I wonder if it is a problem with 7.0(6) software.
Michael
I have the same problems with asa 5510 version 7.2(1)
I have open a TAC service request. And i'm waiting for response.
I post As soon as i have the solution
Best regards
I also opened a TAC case.
Waisted another day to try and fix this.
Will post progress in here.
In the meantime, you can try to do basic config without using alias or name to represent the server - use IP instead.
Also, on the static command, use direct translationwithout using 'port-redirection' mapping. For example:
access-list outside_access_in extended permit icmp any host xx.xx.62.37 --> testing purposes, remove after testing.
static (inside,outside) 217.166.62.37 10.1.1.17 netmask 255.255.255.255
*Use ping test to ensure the host is reachable from outside
*chk ACL using 'sh access-list outside_access_in' to verify incoming traffic hitcount
This can help you to eliminate 'feature' related issue, like using name instead of IP, and direct mapping instead of 'port redirection' format. I used to do this when I first configure the firewall. Once everthing confirm working fine, then only I used the 'fancy' features.
If it's really caused by a bug, the above should not working as well. But it's worth to try.
AK
I am having this same issue with 7.2(1) on a 515E, I would try and create access-list / static's in the same format as you show here only I did not use any names... and for some reason they would not "turn on" even after clear xlate ...etc they did start to work after a bit but I was confused for a long period.
281
