Static NAT Problem---- Help Required
I have Cisco 2600.
serial interface on Public IP and outsite nat enabled
ethernet Interface with Private Ip and Inside NAT Enabled.
I have mapped my LAN machines with the Public IP using Static Nat enteries.
If i try to ping to machines from outside world. i recieve the ping reply,
But I can Telnet any machines with in my network.
No access list applied on my network.
Any suggestions.....
Thanks in advance
Asif
Re: Static NAT Problem---- Help Required
Asif,
If you are able to ping the servers from outside, then the IP Connectivity looks good.
Since there are no access-list applied on the interface, can you make sure that the servers are enabled for telnet services.
Let me know if it helps.
Arul
Arul,
Thanks for reply.
I can access all my machines from with in the LAN,telnet etc.
When i do traceroute from outside world. traceroute stucks at the router where i have applied NAT.
Here is copy of my Running config
-----output suppressed------
controller E1 0/0
channel-group 1 timeslots 1-31
interface Ethernet0/0
description "LAN Connection"
ip address 10.170.10.200 255.255.255.0
ip nat inside
full-duplex
interface Serial0/0:1
ip address 202.125.147.65 255.255.255.252
ip nat outside
ip nat inside source static 10.170.10.254 202.125.148.129
ip nat inside source static 10.170.11.254 202.125.148.130
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 202.125.147.66
ip route 10.0.0.0 255.255.255.0 10.170.10.253
ip route 10.0.1.0 255.255.255.0 10.170.10.253
ip route 10.170.11.0 255.255.255.0 10.170.10.253
ip route 10.170.12.0 255.255.255.0 10.170.10.253
ip route 10.170.14.0 255.255.255.0 10.170.10.60
ip route 192.168.3.0 255.255.255.0 10.170.10.253
line con 0
line aux 0
line vty 0 4
password 7 03514
login
end
____ SOME OUTPUT MODIFIED_____
now i hope u understand better my scenario.
100
