Static Nat question
Hi Everybody,
I face the following issue:
I need to static nat a part of a range to a part of another range.
For the moment, i have the following config:
static (inside,dmz) 192.168.1.0 192.168.2.0 netmask 255.255.255.0 0 0
because, we need to have mapping one to one, to identify the PC using the IP address.
BUT, now, i need to extract one address from this range!!! Is there an option to exclude an address?
i need in final, the following config:
static (inside,dmz) 192.168.1.0 192.168.2.0 netmask 255.255.255.0 0 0 (with the address 192.168.1.10 extracted)
global (dmz) 1 192.168.1.10
nat (inside) 1 192.168.3.0 255.255.255.0 0 0
Thanks in advance,
Marc.
1 REPLY
Bronze
Re: Static Nat question
Yes this can be done using the NAT ID, the NAt will be executed based on this order
For example if you have
Nat(inside) 1 xxxx xxxx
Nat(inside) 2 yyyy yyyy
First Nat 1statement will be checked for a match, if there is not match then it will be checked with the next statement and so on.
161
