Static translation problem
Hi All,
I have the following configuration for DMZ
access-list permit-outside permit ip any any
static (DMZ,external) 1.1.1.0 1.1.1.0 netmask 255.255.255.224 0 0
access-group permit-outside in interface external
1.1.1.0/27 are real ip addresses,
the problem is that if I start pinging hosts from outside to the DMZ I have a large packets loss, and it looks like the hosts behind the pix in dmz are disapearing for 2-3 seconds, then they appear, but if i ping from hosts in DMZ to the outside I do not have packet loss at all.
The same is true for a other protocols, a simple ssh session have the same problems.
Will appreciate any help,
1 REPLY
Silver
Re: Static translation problem
It sounds like it could be an ethernet problem with autonegotiation of speeds. Can the outside hosts and/or dmz hosts reliably ping the interfaces of the PIX? If there is a duplex or speed mismatch between the interfaces of the pix and a managed switch, you could see that kind of packet loss
102
