Static xlate issue from lower to higher security level
The issue I have is that I have a multi interface pix, seperating several business areas. One of these is a sec50 level, which can't be changed. 3 hosts on this segment require internet access which will traverse via the inside sec100 interface. How do I get around the static command as I essentially need a static to allow this interface to xlate to any IP?
As mentioned I can't change the security level to get around this issue...it's probably an easy one but I can't think of the best way. Any help appreciated.
1 REPLY
Silver
Re: Static xlate issue from lower to higher security level
You will need "static" and "access-list" commands to allow traffic to flow from a lower security interface (50) to a higher security interface (100). But the problem here is that the static will have a fixed local address from the "inside" network's range.
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/cmdref/s.htm#wp1026694
You may have to do another translation (using nat and global commands) to these addresses when the traffic exits your network to the Internet.
108
