when pix7.0 act as dhcp server,if it can't set client default gateway,
the command hostname(config)# dhcpd option 3 ip gateway_ip can only use in transparent mode.
and if pix7.0 can only set one gateway,how to do if there are multi subnet in lan?
i wonder dhcp server in pix7.0 can set default gw for client,if it can't ,what will client to do,it must set gw by mannual?
thank you very much?
