strange routing information for nonat private network connection by IPSec
We set up IPSec between two 2610 routers to connect two private networks addressed 192.168.x.0 and 192.168.y.0. The NAT are not used in our system, and we use proxies for internet accesse.
After the following configuration it works fine (the internal private network can see each other).After one month, when we power off one of the router for about 30 minites, and restart it. the connection has a failure. And after 12 days it works angain without much change to the configuration.
The following is the configuration. I want to know is there any bad influence to the internet from the nonat private address? for in the failure time, we find some strange routing information on internet.
Any help will be appreciated !
Sina@quzhj.com
crypto isakmp policy 10
authentication pre-share
crypto isakmp key * address peer addr.
crypto ipsec transform-set * esp-des esp-md5-hmac
crypto map vpn1 10 ipsec-isakmp
set peer "peer addr"
set transform-set *
match address 101
interface Ethernet0/0
ip address internal addr.
no ip directed-broadcast
interface Ethernet1/0
ip address external addr.
crypto map vpn1
ip classless
ip route 0.0.0.0 0.0.0.0 external route
ip route 192.168.x.0 255.255.0.0 internal route
ip route 192.168.y.0 255.255.0.0 external route
no ip http server
access-list 101 permit ip 192.168.x.0 0.0.255.255 192.168.y.0 0.0.0.255
Re: strange routing information for nonat private network connec
YOU MAY WANT TO TAKE A LOOK AT YOUR ACCESS-LIST. BELOW ACCESS-LIST WILL BE MORE PRODUCTIVE;
access-list 101 permit ip 192.168.x.0 0.0.0.255 192.168.y.0 0.0.0.255
Thank you for your advice, but it seems the access-list is not the problem. The x in the address192.168.x.0 is not a single value, it include many different values for different vlans, and y in address 192.168.y.0 is a single value. I am sorry I have made a mistake in my last post about the ip route config. it should be:
ip classless
ip route 192.168.y.0 255.255.255.0 external route
no ip http server
104
