Switches - routers -PAsswords
I finished my CCNA certification 3 months ago.I was working on the network and i had to install a switch
Catalyst 2900 series. OK i started doing some tests and then setting some password etc. Well I have this particular switch which i locked out. I put a password to the console and then now the switch does not respond to the password that i though i put and for that matter it does not respond to any
password at all. Embarrasing, yes.
Now there is a way to reset this switch to a default factory setup type of thing ?
Can I in any manner reset the console password?
Or Should I return the switch to Cisco and explain what happened ?
I will apreciate any help or idea.
J.P.
Re: Switches - routers -PAsswords
Jorge,
You don't specify the Catalyst 2900 model but you can find here all the Cisco equipment recovery procedure
http://www.cisco.com/warp/public/474/
Rob
Thanks A LOT.
The webpage was excelent.It solved my problem.
Well I can see that there is really a lot I need to know about switches and routers. The course was an start point ( i can see that now ) but there is a lot to learn. Some times there is so much that
I do not know where to start ( smile ), but in time I will get it.
Thanks again.
Jorge Prada
CCNA
250
