Syntax for assigning more than one port?
Hello all,
Greatly appreciate all the help I have recieve on this forum.
Is there a way to use and access-list command and eq 5000 to 5020 ports on a single line? I tried ... eq 5000-5020 without success.
TIA,
Gary
1 ACCEPTED SOLUTION
Gold
Re: Syntax for assigning more than one port?
Hi -
Yes you can do this by using 'range' instead of 'eq' i.e.
access-list outside permit tcp host range 5000 5020
Hope this helps -
Yes you can! You need to use the range keyword instead of 'eq'. For example:
access-list outside_access_in permit tcp any host 192.168.1.12 range 5000 5020
Hope this helps...
Marcus
Gold
Hi -
Hope this helps -
174
