Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
synwait and finwait times
when configuring CBAC do you have to put the synwait and finwait times in are will they be turned on by default when configuring CBAC?
1 REPLY
Re: synwait and finwait times
Darren,
When you configure CBAC, if you do not enter a specific value for "tcp synwait-time" or "tcp finwait-time", then a default values is applied.
Please refer the below URL for details:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fsecur_c/ftrafwl/scfcbac.htm#wp1001343
I hope it helps.
Arul
304
