SYSLOG TCP Reset-I & Reset-O
Can any explain what lines in SYSLOG saying "TCP Reset-O and TCP Reset-I" refer to ?
Gold
Re: SYSLOG TCP Reset-I & Reset-O
You'll find the attached document very helpful. TCP Reset-I means that the session was terminated on the Inside, possibly by a server etc and TCP Reset-O means that the session was terminated on the outside!
The attached document will help you understand better.
Please rate post if it helps!!
Jay
Sorry, just one last question ? If the connection is termintd on the inside for example, should you really be seeing a termination then on the outside ?
Thanks in advance
3241
