ovt Bronze
Bronze
sysopt connection permit-ipsec and ACL
Hi!
What does this command exactly do:
- permits ESP and UDP/500 to terminate on PIX?
- permits ESP and UDP/500 to pass thru PIX without ACL checking?
- permits all that is encapsulated within the IPSec packet to pass thru PIX
If this command is *not* used, what does PIX ACL (on outside intf) exactly do:
- check outer IP header only and protocol=ESP?
- check inner IP header only, protocol and ports (TCP/UDP)?
- check *both* outer IP header, protocol=ESP and inner IP header, protocol
(TCP/UDP) and TCP/UDP ports? IOS routers do this way.
Oleg Tipisov,
REDCENTER,
Moscow
  • Other Security Subjects
1 REPLY
Re: sysopt connection permit-ipsec and ACL
Oleg,
SYSOPT CONNECTION PERMI-IPSEC is needed to terminate a VPN on the PIX firewall. It is needed because it bypasses any ACL configured on the PIX.
The command will not listen to ISAKMP (UDP 500): this will be done by ISAKMP ENABLE OUTSIDE.
The command will not listen on ESP : this is done by CRYPTO MAP X INTERFACE OUTSIDE.
Kurt
88
