tarffic translation to box inside does not work (reset-i,506E)
Hello.
I need to redirect smtp traffic coming to external PIX interface to a mail server located inside.
I tried to set up the typical scenario but it does not work.
I'm not successfull until I ping from the internal mail server to the remote sender. The connection can successfully be done during 2 minutes about. Later it cannot connect again.
Thanks a lot for your help.
My config with comments:
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxx
passwd xxxx
hostname fw
domain-name test.cz
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
# - ACL for external iface permitting smtp
access-list 101 permit tcp any host 195.250.132.26 eq smtp log
# ICMP responses permitted
access-list 101 permit icmp any host 195.250.132.26 echo-reply
pager lines 24
logging on
logging buffered informational
mtu outside 1500
mtu inside 1500
ip address outside 195.x.x.x.255.255.248
ip address inside 192.168.1.3 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 192.168.1.5 255.255.255.255 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
# - static translation external:25 -> 192.168.1.5:25
static (inside,outside) tcp interface smtp 192.168.1.5 smtp netmask 255.255.255.255 0 0
# - ACL applying to ext. intarface
access-group 101 in interface outside
route outside 0.0.0.0 0.0.0.0 195.250.132.25 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
terminal width 80
Re: tarffic translation to box inside does not work (reset-i,506
Hello Jaromir,
your config looks ok. Are there any other devices in the path between the external host and the PIX ?
GNT
I agree your config looks OK. I have done a telnet 195.250.132.26 25 from the internet and can't get response .. Are you able to see any smtp hits on your mail server ..?
These addresses are not real, it is just in my testlab.
The problem was in OS on the internal side. I changed the OS and it's working fine.
Please, close the thread.
Thanks very much for your help.
89
