Community Member
tcp port forwarding on pix 501
can you tell me how to forward or open tcp ports 21 and 1024-2774 for the user end of a remote backup system through pix manager or regular here is a copy of my config thanks my apology if its a bit vague Building configuration...
: Saved
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password
hostname pixfirewall
domain-name ciscopix.com
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list allow-out permit tcp any any eq www
access-list allow-out permit tcp any any eq https
access-list allow-out permit udp any any eq isakmp
access-list allow-out permit udp any any eq domain
access-list allow-out permit tcp any any eq telnet
access-list allow-out permit tcp any any eq ftp
access-list allow-out permit icmp any any
access-list allow-out permit esp any any
access-list allow-out permit tcp any any eq ssh
access-list allow-out permit tcp any any eq citrix-ica
access-list allow-out permit tcp any any eq pop3
access-list allow-out permit tcp any any eq smtp
access-list allow-out permit tcp any any eq aol
access-list allow-in permit esp any any
access-list allow-in permit udp any any eq isakmp
access-list allow-in permit icmp any any
access-list allow-in permit tcp any any eq ssh
pager lines 24
interface ethernet0 10baset
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside x.x.x.226 255.255.255.240
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 192.168.1.3 255.255.255.255 inside
pdm location 192.168.1.5 255.255.255.255 inside
pdm location 192.168.1.6 255.255.255.255 inside
pdm location 192.168.1.7 255.255.255.255 inside
pdm location 192.168.1.8 255.255.255.255 inside
pdm location 192.168.1.9 255.255.255.255 inside
pdm location x.x.x.88 255.255.255.255 outside
pdm location 192.168.1.10 255.255.255.255 inside
pdm location 192.168.1.11 255.255.255.255 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) x.x.x.227 192.168.1.9 netmask
255.255.255.255 0 0
static (inside,outside) x.x.x.228 192.168.1.8 netmask
255.255.255.255 0 0
static (inside,outside) x.x.x.229 192.168.1.3 netmask
255.255.255.255 0 0
static (inside,outside) x.x.x.230 192.168.1.5 netmask
255.255.255.255 0 0
static (inside,outside) x.x.x.231 192.168.1.7 netmask
255.255.255.255 0 0
static (inside,outside) x.x.x.232 192.168.1.6 netmask
255.255.255.255 0 0
access-group allow-in in interface outside
access-group allow-out in interface inside
route outside 0.0.0.0 0.0.0.0 216.215.244.225 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323
0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
dhcpd address 192.168.1.2-192.168.1.33 inside
dhcpd dns 64.89.70.2 64.89.74.2
dhcpd lease 2000000
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
Cryptochecksum:xxxxx
: end
[OK]
1 ACCEPTED SOLUTION
Silver
Re: tcp port forwarding on pix 501
Port forwarding is different than allowing ports through the firewall. I guess you meant to allow tcp/21 and port 21 1024-2774 , right?
You need the following lines
access-list allow-in permit tcp any any eq ftp
access-list allow-in permit tcp any any range 1024 2774
YOu can be more specific and can replace "any" with the actual IP addresses
Nadeem
Silver
Nadeem
Community Member
thank you very much
Community Member
Hi Nadeem,
Just to confirm,if ftp access is needed from the outside network to the inside network, ports 21 and 20 and ports 1024 to 2774 need to be allowed on the outside port???
Shervan
Community Member
No, you do not need to manually open all of the ports you mentioned. That is the purpose of the "fixup protocol" commands.
If you need to allow someone to FTP from outside to inside, you need only open ftp.
Example One:
Allows external network 12.13.2.0 to access any internal machine that is running FTP server:
access-list ALLOW-FTP permit tcp 12.13.2.0 255.255.255.0 any eq ftp
access-group ALLOW-FTP in interface outside
Example 2:
Allows a single external host to access any internal machine running FTP server:
access-list ALLOW-FTP permit tcp host 12.13.2.4 any eq ftp
fixup protocol ftp 21 will handle the way ftp communications work.... so add the above access rule and as long as the default fixup protocols are in place, you'll be fine.
289
