TCP Reset-I
I am getting the follwong message in our PIX log: 2006-07-14 11:44:28 Local4.Info 192.168.12.9 %PIX-6-302014: Teardown TCP connection 52170120 for dmz1:192.168.*.*/64894 to inside:192.168.*.*/25 duration 0:00:00 bytes 0 TCP Reset-I. I know that the -I in the TCP Reset tells me that it is from the inside but inside what. This traffic is between the DMZ and inside interfacces, can I tell what direction the reset came from?
Hall of Fame Super Silver
Re: TCP Reset-I
You have asked the same question in the firewalling forum where it has received several answers. I suggest that we consolidate the discussion in that forum.
Rick
Re: TCP Reset-I
The duplication was an accident, sorry for the inconveince. I would appreciate your opinion, I havent recieved an answer to my question. Since the PIX only will report Reset-I or Reset-O what will it report when the reset comes from a DMZ?
310
