Community Member
Telnet sessions not responding
HI,
I am unable tp take more than 2 telnet connections to PIX 535.The new sessions are getting rejected with a error message as TCP management connections are full.
who gives only the 2 sessions connected, but sh processes gives there is 3 other sessions, but unable to get session id for killing the same.
1 REPLY
Re: Telnet sessions not responding
can u confirm with you config whether you have permitted the access for the other ips too to telnet onto ur equipment ??
By default it can server max 5 connections but you need to allow them in the configuration..
can you check and paste the telent related config lines in ur pix ??
regds
160
