Telnet to inside Interface through the VPN
How can I telnet to PIX inside interface from the VPN (I.E. from 10.128.128.0 telnet 172.16.3.252).
I have tried using telnet command:
"telnet 10.128.128.0 255.255.224.0 inside" but still no working.
Can you help me?
Dante
Follow: I've included the confs:
CONF MAIN PIX
PIX Version 6.0(1)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 DMZ1 security10
nameif ethernet3 intf3 security15
nameif ethernet4 intf4 security20
nameif ethernet5 intf5 security25
enable password *********** encrypted
passwd ********** encrypted
hostname MAIN
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list 101 permit ip 10.128.128.0 255.255.224.0 172.16.3.0 255.255.255.0
access-list 102 permit ip 10.128.128.0 255.255.224.0 192.168.3.0 255.255.255.0
access-list 103 permit ip 10.128.128.0 255.255.224.0 10.250.1.0 255.255.255.0
access-list 103 permit ip 10.128.128.0 255.255.224.0 10.249.0.0 255.255.240.0
access-list 104 permit ip 10.128.128.0 255.255.224.0 10.250.11.0 255.255.255.0
access-list 105 permit ip 10.128.128.0 255.255.224.0 10.250.95.0 255.255.255.0
pager lines 24
logging on
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
interface ethernet3 auto
interface ethernet4 auto shutdown
interface ethernet5 auto shutdown
mtu outside 1500
mtu inside 1500
mtu DMZ1 1500
mtu intf3 1500
mtu intf4 1500
mtu intf5 1500
ip address outside 200.219.100.2 255.255.255.0
ip address inside 10.128.159.253 255.255.224.0
ip address DMZ1 10.255.255.254 255.255.224.0
ip address intf3 10.250.11.254 255.255.255.0
ip address intf4 127.0.0.1 255.255.255.255
ip address intf5 127.0.0.1 255.255.255.255
ip audit info action alarm
ip audit attack action alarm
no failover
failover timeout 0:00:00
failover poll 15
failover ip address outside 0.0.0.0
failover ip address inside 0.0.0.0
failover ip address DMZ1 0.0.0.0
failover ip address intf3 0.0.0.0
failover ip address intf4 0.0.0.0
failover ip address intf5 0.0.0.0
pdm history enable
arp timeout 14400
global (outside) 1 200.219.100.100-200.219.100.199
global (outside) 1 200.219.100.200
global (DMZ1) 1 10.255.224.10-10.255.224.70
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
nat (DMZ1) 1 0.0.0.0 0.0.0.0 0 0
alias (inside) 200.219.100.26 10.255.224.3 255.255.255.255
alias (inside) 200.219.100.30 10.128.128.30 255.255.255.255
alias (inside) 200.219.100.31 10.255.224.9 255.255.255.255
alias (inside) 200.219.100.54 10.255.224.4 255.255.255.255
static (inside,outside) 200.219.100.26 10.128.128.26 netmask 255.255.255.255 0 0
static (inside,outside) 200.219.100.30 10.128.128.30 netmask 255.255.255.255 0 0
static (inside,outside) 200.219.100.31 10.128.128.32 netmask 255.255.255.255 0 0
static (inside,outside) 200.219.100.54 10.128.128.54 netmask 255.255.255.255 0 0
conduit permit icmp any any
conduit permit tcp host 200.219.100.30 eq www any
conduit permit tcp host 200.219.100.30 eq domain any
conduit permit udp host 200.219.100.30 eq domain any
conduit permit tcp host 200.219.100.31 eq www any
conduit permit tcp host 200.219.100.31 eq domain any
conduit permit udp host 200.219.100.31 eq domain any
conduit permit tcp host 200.219.100.26 eq 161 any
conduit permit tcp host 200.219.100.26 eq 162 any
conduit permit udp host 200.219.100.26 eq snmp any
conduit permit udp host 200.219.100.26 eq snmptrap any
conduit permit tcp host 200.219.100.54 eq domain any
conduit permit udp host 200.219.100.54 eq domain any
conduit permit tcp host 200.219.100.54 eq 22 any
route outside 0.0.0.0 0.0.0.0 200.219.100.1 1
route outside 10.0.64.0 255.255.224.0 10.128.159.252 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
snmp-server host inside 10.128.128.21
snmp-server location mainsite
snmp-server contact support@mainsite
snmp-server community pixpix
snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
sysopt ipsec pl-compatible
no sysopt route dnat
crypto ipsec transform-set strong esp-des esp-sha-hmac
crypto map cmap 1 ipsec-isakmp
crypto map cmap 1 match address 101
crypto map cmap 1 set peer 200.200.100.2
crypto map cmap 1 set transform-set strong
crypto map cmap 2 ipsec-isakmp
crypto map cmap 2 match address 102
crypto map cmap 2 set peer 200.200.111.2
crypto map cmap 2 set transform-set strong
crypto map cmap 3 ipsec-isakmp
crypto map cmap 3 match address 103
crypto map cmap 3 set peer 200.200.222.2
crypto map cmap 3 set transform-set strong
crypto map cmap 4 ipsec-isakmp
crypto map cmap 4 match address 104
crypto map cmap 4 set peer 200.202.202.2
crypto map cmap 4 set transform-set strong
crypto map cmap 5 ipsec-isakmp
crypto map cmap 5 match address 105
crypto map cmap 5 set peer 205.205.205.2
crypto map cmap 5 set transform-set strong
crypto map cmap interface outside
isakmp enable outside
isakmp key ******** address 200.200.100.2 netmask 255.255.255.255
isakmp key ******** address 200.219.100.4 netmask 255.255.255.255
isakmp key ******** address 200.200.111.2 netmask 255.255.255.255
isakmp key ******** address 200.200.222.2 netmask 255.255.255.255
isakmp key ******** address 200.202.202.2 netmask 255.255.255.255
isakmp key ******** address 205.205.205.2 netmask 255.255.255.255
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash sha
isakmp policy 10 group 1
isakmp policy 10 lifetime 3600
telnet 10.128.128.0 255.255.224.0 DMZ1
telnet timeout 5
ssh timeout 5
CONF of office1 PIX:
PIX Version 6.1(1)
enable password ************** encrypted
passwd *********** encrypted
hostname office1
fixup protocol rtsp 554
names
access-list 101 permit ip 172.16.0.0 255.255.0.0 192.168.3.0 255.255.255.0
access-list 102 permit ip 172.16.0.0 255.255.0.0 10.128.128.0 255.255.224.0
pager lines 24
logging on
mtu outside 1500
mtu inside 1500
ip address outside 200.200.100.2 255.255.255.240
ip address inside 172.16.3.252 255.255.255.0
pdm history enable
arp timeout 14400
global (outside) 1 200.200.100.3-200.200.100.10
global (outside) 1 200.200.100.11
nat (inside) 1 172.16.0.0 255.255.0.0 0 0
static (inside,outside) 200.200.100.12 172.16.3.25 netmask 255.255.255.255 0 0
conduit permit gre any any
conduit permit udp host 211.211.211.251 eq domain any
conduit permit tcp host 211.211.211.251 eq domain any
conduit permit tcp host 211.211.211.251 eq smtp any
conduit permit udp host 211.211.211.251 eq 25 any
conduit permit tcp host 200.200.100.12 eq domain any
conduit permit udp host 200.200.100.12 eq domain any
conduit permit tcp host 200.200.100.12 eq smtp any
route outside 0.0.0.0 0.0.0.0 200.200.100.1 1
route inside 172.16.15.0 255.255.255.0 172.16.3.254 1
route inside 172.17.0.0 255.255.0.0 172.16.3.254 1
snmp-server host outside 200.219.100.26
snmp-server location "Office1"
snmp-server contact support@office1
floodguard enable
crypto map cmap 10 ipsec-isakmp
crypto map cmap 10 match address 101
crypto map cmap 10 set peer 200.200.111.2
crypto map cmap 10 set transform-set strong
crypto map cmap 20 ipsec-isakmp
crypto map cmap 20 match address 102
crypto map cmap 20 set peer 200.219.100.2
isakmp key ******** address 200.219.100.2 netmask 255.255.255.255
isakmp identity address
telnet 172.16.3.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
terminal width 80
Re: Telnet to inside Interface through the VPN
there is prob. a better way . But I can tell you what I do. If you have a machine on the inside network like a unix box or a router. give that machine telnet access to the PIX. then when u VPN in, you will defn. be able to telnet that inside machine from there you can telnet the inside interface.
hope this helps
I use SSH on the outside interface. You use the command exactly like the telnet command. for example, ssh x.x.x.x 255.255.255.255 outside. Be careful with what addresses you allow to connect.
There are 2 caveats however. You have to have 3des enabled and you need to generate an RSA key.
although officially you cannot telnet to the outside, with vpn you can. so your telnet command will be applied to the outside. Then you must change your acl's to permit the other inside network to the outside ip of the pix, and vice versa on the other side.
119
