Telnet to PIX within LAN to LAN
I have a quick question, i have a LAN to LAN tunnel setup between two PIXs, if i setup telnet for the other side of the network, can i telnet to the internal interface of the other side of the PIX
network A-----PIX A--------VPN Tunnel--------PIX B--------network B
can i telnet from network A to th PIX B's internal inteface?
look forward for your reply, thanks.
1 REPLY
Re: Telnet to PIX within LAN to LAN
If you upgrade both PIX's to 6.3 and use the new "management-access" command, then yes, you can. You'll be able to ping, Telnet, SSH, etc to the internal interface.
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/cmdref/mr.htm#1137951
86
