Terminal Service problem
I have set up TS running through to our TS machine via external IP x.x.x.85 and it runs fine. I have a problem with one of our users who insists on using TS to connect to his machine at home during work hours since this hole was opened up again.
Is there a way to block TS traffic for everywhere except the external IP we are using for demos x.x.x.85?
He does not know this IP address and would probably be fooled by it. TS needs inbound and outbound traffic on ports 80 and 3389 for our purposes as we use TSWEB for our demos.
Other addresses:
Internal address of TS server 192.168.11.150
Internal address of pesky user 192.168.11.12
I want to do this through the PIX if possible as it means I do not have to set up Proxy Server for one user.
PIX 515 running OS 6.22
Please copy post to gheatleyat ssmicdotcom , thanks.
Re: Terminal Service problem
try an access-list on the inside interface that permits these 2 ports for destination address .85 but blocks the ports for all other addresses, then permit ip any any as the third entry. or you could try blocking these ports when the source address is the pesky user.
I would rather try the second option. Can you point me to a document that will take me through the commands please?
Glyn
93
