Test a IDS Installation
How could I test a IDS installation?
I have a 4210 well configured... I hope. I've tested sensor-CSPM communications and are working well.
Is there a kind of ping or something like that for a detection from my IDS?
1 REPLY
Re: Test a IDS Installation
There might be an easier way, but I use CIS's Internet Scanner software (freeware). Load it on your PC, pick a host to scan and let the Scanner do it's thing. The IDS will report like ten or so alarms on the CSPM event viewer...Hope this helps...
89
