TFTP udp port
I have put a rule in an extended access-list permitting udp port 69 (tftp), but my tftp connections do not work. I have put both directions (any eq tftp any + any any eq tftp).
I have put a log at the end of the access-list and I have seen that the communication is in port udp 3000 once and the second time in udp port 6731. I think tftp is not working in the correct port, it seems to be a bug.
What do you think? Have you seen something similar?
TIA
Re: TFTP udp port
TFTP works like this: the client issues the first packet using udp port grater than 1023 to port 69 on the server.
The server responds using a port number grater than 1023 to the original port used by the client.
The rest of the conversation is carried out using the last to port numbers.
Re: TFTP udp port
is there any possibility to catch the TFTP traffic?
For example with some range of the ports for server side.
2337
