The best way to resove this if possible would be to rebuild your tcp/ip configuration on the pc. Uninstall the current installed client.
Try and download the latest driver for the NIC, remove the currnet network driver, remove tcp/ip, Reinstall the NIC with the new driver, reinstall tcp/ip, then reinstall the service pack, make sure ip connectivity works , and then reinstall the client.
