Community Member
The problem has been solved! The custom's host has another path to outside.
I config the static nat in pix and use global / nat command to make source nat for inside host's internet connection. But when i try to connect the map ip config in pix as static ip, it dosen't work. I sniffor the packet and find the the source ip address which response from remote server(pix) is still the private ip address of the inside host, and hasn't been translate to public ip address.
and the ping result is :
C:\>ping 218.x.179.3 -t
Pinging 218.x.179.3 with 32 bytes of data:
Reply from bytes=32 time=25ms TTL=55
218.x.179.3 is the map ip address. is the host ip address.
and show xlate is :
4 in use, 14 most used
Global 218.x.179.4 Local
Global 218.x.179.3 Local
Global 218.x.179.5 Local
Global 218.x.179.6 Local
seems ok, too.
why pix dose't translate the inside ip to the map ip? is it bug in 6.3(1) os???
the configuration is the following:
pixfirewall# sho run
: Saved
PIX Version 6.3(1)
interface ethernet0 100basetx
interface ethernet1 100basetx
interface ethernet2 auto shutdown
interface ethernet3 auto shutdown
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 intf2 security4
nameif ethernet3 intf3 security6
enable password xxx
passwd xxx
hostname pixfirewall
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
access-list acl_in permit ip any any
access-list acl_in permit icmp any any
pager lines 24
mtu outside 1500
mtu inside 1500
mtu intf2 1500
mtu intf3 1500
ip address outside 218.x.x.2
ip address inside
no ip address intf2
no ip address intf3
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0 0
static (inside,outside) 218.x.x.4 netmask 0 0
static (inside,outside) 218.x.x.5 netmask 0 0
static (inside,outside) 218.x.x.6 netmask 0 0
static (inside,outside) 218.x.x.3 netmask 0 0
access-group acl_in in interface outside
route outside 0.0.x.x.77.179.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
: end
Re: The problem has been solved! The custom's host has another p
Hi ... I suggest you to upgrade to latest 6.3 (5) version ... your config seems OK.
I hope it helps ... please rate it if it does !!!
