There is not ping from inside to dmz zone on PIX515
I have got PIX 515.
ip address outside 1.1.1.130 255.255.255.128
ip address inside 172.16.8.5 255.255.255.128
ip address dmz 1.1.1.1 255.255.255.128
I have host at inside:
172.16.8.1 255.255.255.128 gateway 172.16.8.5
I have host at dmz 1.1.1.2 gateway 1.1.1.1
Why I can not ping from inside 172.16.8.1 to dmz 1.1.1.2,
but I can ping 172.16.8.5 from inside 172.16.8.1
and I can ping 1.1.1.1 from dmz 1.1.1.2 ?
And why I can not ping outside 1.1.1.129 (directly connect to outside 1.1.1.130 of PIX)
from dmz zone 1.1.1.2 ?
PIX Version 6.3(3)
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security4
enable password cisco
passwd cisco
hostname pix515
domain-name prbb.ru
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list outside_access_in permit ip any 1.1.1.0 255.255.255.0
access-list dmz_access_in permit ip any any
access-list inside_access_in permit ip any any
pager lines 24
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip audit info action alarm
ip audit attack action alarm
pdm location 172.16.8.1 255.255.255.255 inside
pdm location 172.16.8.0 255.255.255.0 inside
pdm location 172.16.0.8 255.255.255.255 inside
pdm location 1.1.1.2 255.255.255.255 dmz
pdm history enable
arp timeout 14400
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
access-group dmz_access_in in interface dmz
route outside 0.0.0.0 0.0.0.0 1.1.1.129 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 172.16.8.1 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
management-access inside
console timeout 0
username cisco password cisco privilege 15
terminal width 80
Silver
Re: There is not ping from inside to dmz zone on PIX515
Nat is neither on or off. This is sort of like having your car in neutral. You need to do somthing like:
nat (inside) 0 0.0.0.0 0.0.0.0
nat (dmz) 0 0.0.0.0 0.0.0.0
nat (outside) 0 0.0.0.0 0.0.0.0
HTH pls rate!
Silver
*** PLEASE RATE IF THIS HELPS*****
1. To be able to ping from inside to dmz you need to add a nat and global plus an acl on the dmz..
EX. nat (inside) 1 172.16.8.0 255.255.255.128
global (dmz) 1 1.1.1.0 255.255.255.128
access-list dmz_access_in extended permit icmp any any echo-reply
2.You can ping local addresses on the dmz or inside because they NEVER hit the firewall.
3. The problem with pinging the outside from the dmz is the same as inside to dmz here is the config for that..
EX.
nat (inside) 1 172.16.8.0 255.255.255.128 (don't need if you input it in step #1)
global (outside) 1 1.1.1.128 255.255.255.128
access-list outside_access_in extended permit icmp any any echo-reply
You have contradictory rules set. The security on the Inside interface is set to protect the Inside interface but the other two have different security levels. You have two methods to deal with the problem.
1. Set the security levels on all interfaces to 100. This would solve the issue indicated above or
2. Enable NAT, specify a static route from the outside to the inside addresses you want them to have access to and then enable the appropriate firewall rules.
As of now, your Security levels are set to STOP any direct rules from the outside to the inside.
1.) Note: ICMP is not a stateful protocol. You need to configure an access-list that permits the icmp protocol. See guides bellow.
2.) The security levels are fine, this is the standard setup. Do not change it to equal levels.
inside = 100
outside = 0
dmz = 1-99
3.) Problem with access from the dmz to the outside as it is also for inside you need a
valid NAT statement or a static.
global (outside) 2 x.x.x.2
global (outside) 1 x.x.x.3
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
nat (dmz) 2 1.1.1.0 255.255.255.128 0 0
This might not be a really good example.
Reference Guides:
The PIX and the traceroute Command:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00800e9312.shtml
Handling ICMP Pings with the PIX Firewall:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094e8a.shtml
This post will probably not cover all your question but it might be a good start point.
sincerely
Patrick
242
