tg
Community Member
To concentrate or not
I have a central site and 3 small remote sites.
Do I need Cisco VPN concentrators at all sites or only at the central site?
Or can I do it just with Cisco routers with VPN capabilities?
1 REPLY
Community Member
Re: To concentrate or not
I always recommend offloading the IPsec from the routers or at a minimum use the available encryption modules. It’s very taxing on a router to process these tunnels so a stand-alone device is definitely a better alternative. The concentrators are excellent, fast & reliable. If the remote sites are small enough or there are budget considerations, you can start with terminating the remote site routers to the concentrator at headquarters.
114
