Token Ring and VPN?
Is it possible to have a site to site VPN between two Cisco 2600s that are running Token Ring on the LAN?
If anyone has a URL with info on this I'd appreciate it. I am not finding anything.
Thank!
  • Other Security Subjects
1 REPLY
Re: Token Ring and VPN?
This shouldn't be any different to any other interfaces, although I haven't tried it personally. I've built VPN's over many different types of interfaces.
I know that the VPN client won't work over a TR interface in the PC, but a L2L connection shouldn't have a problem. Just create the crypto map as normal, then apply the map to the TR interface, there shouldn't be anything specific you need to do.
90
