Error Message - %PIX|ASA-6-302014: Teardown TCP connection id for
interface:real-address/real-port to interface:real-address/real-port duration hh:mm:ss bytes
bytes [reason] [(user)]
Explanation - A TCP connection between two hosts was deleted. The following list describes the message values:
â¢connection id is an unique identifier.
â¢interface, real-address, real-port identify the actual sockets.
â¢duration is the lifetime of the connection.
â¢bytes bytes is the data transfer of the connection.
â¢user is the AAA name of the user.
The reason variable presents the action that causes the connection to terminate.
Error Message - %PIX|ASA-6-106015: Deny TCP (no connection) from IP_address/port to
IP_address/port flags tcp_flags on interface interface_name.
Explanation - The security appliance discarded a TCP packet that has no associated connection in the security appliance connection table. The security appliance looks for a SYN flag in the packet, which indicates a request to establish a new connection. If the SYN flag is not set, and there is not an existing connection, the security appliance discards the packet.
Recommended Action - None required unless the security appliance receives a large volume of these invalid TCP packets. If this is the case, trace the packets to the source and determine the reason these packets were sent.
