07-02-2008 04:25 AM - edited 03-09-2019 09:00 PM
Hello - I was wondering if someone could tell me why I get this error in my syslog from my ASA 5520:
3|Jul 02 2008 08:00:43|305005: No translation group found for udp src Inside:MAILBOX/49572 dst Inside:192.168.200.19/1176
I see it quite a bit. The 192.168.200.X address is the address pool for VPN users, and MAILBOX is our exhange server. I have a static route set up for MAILBOX (static (Inside,outside) X.X.X.X MAILBOX netmask 255.255.255.255) so I don't understand why I get this error. Thanks!
07-02-2008 07:43 AM
According to the syslog, it seems that the UDP traffic is coming in from the inside interface and going to the inside interface.
Questions:
Which interface on your ASA does terminate the VPN clients?
What is the internal network IP address range?
I see that the VPN users are getting IP address in the range 192.168.200.x -
Do you have NAT exemption configured?
Can you send me the output of "sh run nat" from the ASA.
Gilbert
07-02-2008 07:51 AM
Aha - it was the NAT exemption - just configured that and these errors stopped. Thanks!
07-02-2008 08:21 AM
Awesome. Good to know that it is solved.
Rate this post, if it helped.
